Another oil leak thread....
Old 12-14-2013, 10:23 PM
The PCV system works the opposite way. You need to make sure everything is sealed tight and ONLY vents through the hose pointed out in the above pic. Oil cap O-ring, dipstick O-ring and that hose needs to be clamped etc.. No valve, open all the time.
The engine is aluminum alloy not cast iron, heat affects the sealing surfaces. I'm betting the engine overheated severely at some time.
donbrew is offline
Old 12-14-2013, 10:41 PM
Leo-
If a 2nd dye test confirms the leak IS between upper & lower block, I would try some reputable brand of stop leak for the crankcase B4 removing the engine..
Ya never know, might work.
sleeper is offline
Old 12-14-2013, 10:45 PM
leo pinetree's Avatar
Thanks everyone for the responses. I did think about a stop-leak type product but the seal is a bead of some silicone-like material and not a gasket but it is certainly worth a try. I will get a second opinion and let you guys know how it goes.
leo pinetree is offline
Old 12-15-2013, 07:34 PM
Perhaps a good steam cleaning will revel the leak, and I think the stop leak type product may help if there is not much pressure at the leak
Oldblue is offline
Old 02-21-2020, 03:14 PM
stts's Avatar
what a bummer. I guess oil can leak out where the block halfs come together. I just drove 500 miles on my cleaned up 2006 with a 2.4 thats running strong and smooth. But its not so clean any more. the lower half of engine is covered in about a quart of oil. Upper half is still clean. I knew oil was leaking but figured it was all from the oil cooler. It was tricky to get to but I replaced the 2 rotten seals. But that split is still got oil all over on the intake manafold side and pooled oil under the cooler on top of the bell housing. I have an oil gage on the engine and its 100 psi when cold and drops to 75 psi with hot oil. Never seen oil pressure that high. At hot idle its 20psi. No oil and water mixing yet, so I guess thats a bit of good news. Its really stupid that its only silicone and not a gasket between the engine halfs. I may also try that oil leak additive to slow down the leak. I think I would rather just keep feeding it oil than to tear the engine apart. Just for grins Ill do a dye test when I get back home but its sooo messy at the split after its been engine cleaned that it must be the split thats spewing so much oil.
stts is offline
Old 02-21-2020, 04:42 PM
You should clean it up real good, and carefully monitor it. Find out exactly where it's leaking.
RJ_RS_SS_350 is offline
Old 02-21-2020, 05:11 PM
Clean it and apply sealant to the are where the leak was
Oldblue is offline
Old 02-21-2020, 08:56 PM
You know in the mid 1950's Harley didn't use any Head Gaskets on their (WR & KR) Flatheads, They just lapped the mating surfaces till they had precise surfaces & bolted it together.
Worked great.
sleeper is offline
tylerz71
08-17-2022 07:02 PM
billmac77
02-20-2019 05:51 PM
gag
04-24-2013 11:10 AM
DaytonaBlueMetallic
03-13-2013 12:07 PM
camaro98z28
08-10-2010 08:10 PM
Quick Reply: Another oil leak thread....
