Anti theft / U0073
Old 09-25-2024, 04:36 PM
foltzkr's Avatar
Well new battery got me a week. I went about 2 miles, pulled into a McDonald’s to get a drink. While I was going through th parking lock the power steering waning came on and then the anti theft. I’m sitting in the parking lot with the battery disconnected.
not sure what we should be checking.
15 minutes-started got about a mile and happened again.
Had to get it towed home. Anti theft or limp mode with check engine light on. my anxiety about figuring this out, is going to the roof.
Is the anti theft the problem. Or is it the 0073 it throws after……. I am stumped about how to trouble shut this.
foltzkr is offline
Old 09-25-2024, 04:54 PM
foltzkr's Avatar
I did the key on 3 times reset……
foltzkr is offline
Old 09-30-2024, 09:29 AM
PulpFriction's Avatar
Interesting that a new battery did any good at all. A failing power steering motor draws excessive power. if you’re having any trouble at all with the power steering, you could try taking it to a GM dealer and talk to them about a recall or extended warranty on the power steering motor, whichever applies, and one or the other does. Either should be a $0 repair.
PulpFriction is offline
Old 09-30-2024, 04:40 PM
Some descriptions of this procedure don't mention that each time you turn the key to "off", you need to leave it off for 5 seconds.
RJ_RS_SS_350 is offline
Old 09-30-2024, 04:45 PM
Or that it’s also called the 30 minute relearn. 10 minutes for each step.
firemangeorge is online now
TaraP
12-06-2022 10:59 AM
Alicia Kirk
12-26-2015 08:20 PM
dadman503
07-15-2013 04:03 PM
lizyness08
10-22-2012 02:20 PM
da_loca
12-08-2006 12:34 AM
Quick Reply: Anti theft / U0073
