Any 5 VDC available in Vehicle?
Old 03-06-2009, 05:45 AM
NxlKing2304's Avatar
Originally Posted by Lucky
x2 don't make the car fit you needs adapt the phone charger it fit the car.
Definately. I'm with Lucky. If your trying to power your cell phone, just tap into the 12V through a standard Car Charger. You can even hard wire it in as well, instead of taking up one of your Lighter Sockets.
I would not do this any other way.
NxlKing2304 is offline
Old 03-08-2009, 10:56 AM
mistermike's Avatar
5V is easily obtained with a simple 3 pin regulator off any 12V circuit. I would never in a million years attempt to tap 5V from any pin going back to the ECM.
mistermike is offline
Old 03-08-2009, 04:52 PM
Sno White's Avatar
Solution was right in front of my EYES!
A RADIO normally has lots of voltages and reserve power, so close to the dash storage box too. Found my radio supplied 5VDC and it didn’t charge my cell phone; found 8VDC, it didn’t work either, but 8.5VDC did work. AND the radio & CD still works.
Turns out the Specifications on the Cell phone's AC power adapter lies. Yes, it is “rated” 5VDC only after first supplying 9VDC to the phone, there after the voltage fluctuates. Turns out this AC adapter is smart.
Sno White is offline
HillsdaleHHR
07-16-2012 06:59 PM
Doctuh
04-25-2012 07:05 PM
stephofthedead
01-16-2011 12:08 AM
davkat
10-10-2009 09:40 PM
Neogenic
09-08-2009 06:02 AM
Quick Reply: Any 5 VDC available in Vehicle?
