Any issue getting an alignmnet after installing rear sway bar?
Old 06-27-2007 | 07:42 PM
Goose's Avatar
Not really a problem but wondering if I bring my HHR in for an alignment could they blame any issues on the sway bar? Does it even come into play during an alignment?
Goose
Old 06-27-2007 | 07:48 PM
Lone Ranger's Avatar
Should not be a factor.
Old 06-27-2007 | 08:02 PM
Goose's Avatar
ok, I'm just asking because I'm bringing my HHR in to have the front bowtie replaced and am going to ask for an aligment and maybe a balance while it is there (little jittery ride on the highway) I have a feeling they would point to the sway bar and blame that
Goose
Old 06-27-2007 | 08:13 PM
Didn't seem to effect mine. Though I think I need one after my new springs.
Old 06-28-2007 | 02:15 AM
MrVette's Avatar
The rear sway bar should not be a problem with the front alignment.
Old 06-28-2007 | 06:32 AM
Goose's Avatar
Is there any rear alignment necessary for the HHR or is it front only?
Goose
Old 06-28-2007 | 06:51 AM
solman98's Avatar
Goose
HHR has a rear alignment also. The sway bar "should" not affect it. Is this a vibration you felt after the install and not before? If so, just check under again and see if you can see anything that might have moved since. I would also take the bar out, see if the vibration is gone, and then reinstall and see if it comes back before I take to the dealer. They see that bar and might blame everything on it.
Old 06-28-2007 | 01:32 PM
Goose, if you need an alignment, try to find a shop that has the computerized Hunter rack. The Hunter equipment is really good.
Old 06-28-2007 | 01:35 PM
Goose's Avatar
Will do LR....hope the dealer has one as they will be doing it...just noticed I misspelled alignment in my title...doh!
Goose
PanelMan
"How To" Tutorial Library
84
11-13-2015 10:42 PM
The_Engineer
Maintenance and Upkeep
13
06-06-2015 01:41 AM
TiggersHHR
03-11-2011 10:35 AM
Hiperguy
11-11-2010 09:34 PM
Quick Reply: Any issue getting an alignmnet after installing rear sway bar?
