Any thoughts? Clutch issue?
Old 09-08-2024 | 10:52 AM
Applejr's Avatar
Driving home I pushed in the clutch, it went to the floor and the assist spring fell off. I couldn’t find a replacement but I found a spring (not for hhr) in the junkyard and tried to make it work. Anyway..I heard the spring isn’t a big deal and sometimes people remove it.. in any case my car now won’t go into gear while it’s running. Any idea what the issue is?
Old 09-08-2024 | 11:15 AM
Welcome to the site, first I see you have a 2008 5 speed manual, but which engine? 2.0 in an SS, 2/2 in an LS , 2.4 in an LT? Are your shift cables lubed and moving or sticking and seizing up?
Old 09-08-2024 | 11:19 AM
to the forums!
I edited your thread title.
The spring is no longer available.
You say that you tried to make a different spring work. Were you successful? The spring is a big deal, if the pedal doesn't return, your vehicle won't be in gear.
There was a member who had a spring made, I'll see if I can find that information.
Old 09-08-2024 | 11:23 AM
This clutch spring supplier?
https://www.chevyhhr.net/forums/hhr-...upplier-66984/
Old 09-08-2024 | 11:24 AM
That's the one!
Old 09-08-2024 | 11:26 AM
I merged the 2 threads to avoid double posts
Old 09-08-2024 | 11:30 AM
As I asked in post #2 , are your shift cables sticking ?
Old 09-08-2024 | 11:34 AM
Applejr's Avatar
Thanks
Please bear with me if I’m posting incorrectly 😆 I’m still learning to navigate the room. I’m not sure how to answer an individual question but No I was not successful with the spring. I drilled a hole on each side of the bracket to fit the new spring. Then another,then another. Still couldn’t get it to fit. So I tried to bend the much thicker spring and snapped it half. So now I have a half of spring on it. I started it up and it won’t go into gear while running. If I start it in gear it will take off. Everything was functioning perfectly until the spring flew off
Old 09-08-2024 | 11:36 AM
Applejr's Avatar
Cables
No the cables don’t seem to be sticking or anything, the clutch pedal also returns by itself but to push it down without the spring there is no pressure
Old 09-08-2024 | 11:52 AM
If the issue is that the shifter just won't go into position, then you may need to adjust the shifter cables. This provides proper alignment. The adjustment is at the shifter, inside the center console. One cable adjusts the alignment east-west, the other adjusts north-south.
But strange is that the vehicle tries to move with the pedal depressed.
Quick Reply: Any thoughts? Clutch issue?
