Auto door lock inop
Old 12-11-2017 | 10:07 AM
postalboy's Avatar
Auto door lock inop
When I place my hhr in park it has always unlocked all door and when I remove it from park it locks all doors. This no longer works.I can still lock all doors with the switch on the drivers door or by the key remote. I also can hear a click in the shifter when I push the brake pedal.
Old 12-11-2017 | 10:16 AM
Did you check the customization menu on the DIC.
If you don't have a Owner Manual you can get a free digital one from the link in my sig.
Old 12-11-2017 | 10:32 AM
postalboy's Avatar
I have not checked the DIC menu but I will. This is a 2007 LS with 46207 miles and the original battery.
Old 12-11-2017 | 01:54 PM
Get a new battery before you really need it. They installed 6 year batteries at the factory.
Old 12-11-2017 | 04:31 PM
postalboy's Avatar
DIC menu is fine. I think I will replace the battery although I will have it checked first. I can feel the click in the shifter if I have my hand on it when I step on the brake. The click started while I was driving, then no auto door lock when I stopped.
Old 01-23-2018 | 12:19 PM
postalboy's Avatar
Ok, after over one month of my sifter door lock problem everything started to work again. I did nothing except drive the car and put up with it not working. Any thoughts?
Old 01-23-2018 | 02:50 PM
Probably a micro-switch sticking in the shifter assembly.
hhr06NJ
08-25-2014 09:58 PM
aloppen
11-13-2011 03:01 PM
BlackScreaminMachine
06-22-2010 04:34 PM
Rotor
06-15-2010 06:32 PM
impulse91
07-16-2009 09:21 PM
Quick Reply: Auto door lock inop
