auto trans gear lock
Old 02-22-2007 | 01:35 PM
rickremixx's Avatar
anyone hear about HHR problems with auto trans gear lock getting stuck and not being able to put the car in gear ??
dealer say common problem
Old 02-22-2007 | 01:49 PM
HHR PNOY's Avatar
Had an 06 1LT (purchased April 06) and I never had this problem, not even once.
Old 02-22-2007 | 01:50 PM
Don't recall this ever being a topic of discussion here. Keys stuck in ignition, yes. But not being able to put car in gear.
I'm sure there will be a lot of suggestions with this one being the most suggested.......
Make sure you press the brake pedal first before trying to move shifter. That's probably the closest we ever discussed that here.
Old 02-22-2007 | 02:05 PM
rickremixx's Avatar
lol yeah we pressed the break all the way lol
just talk dealer he said they have problems with some
solenoid thing in gear shift , the dealer said 11,000 hhr had this problem so far ?
Old 02-22-2007 | 02:35 PM
GRUMPEE's Avatar
I reported the problem in an earlier post. Dec.06. Started the Car, put my foot on the break to shift out of PARk, but noticed the gear shift button(trigger?) wouldn't depress completely. Had to have it dolly towed to the dealer. In my case I could hear the solonoid engage, but because of the trigger it felt more like a mechanical problem. According to the dealer paperwork, the shifter was replaced. Had to wait over a week because it was the holidays and they didn't have the part stocked. Luckily it was under warranty including the rental (07HHR)
So far that has been the only problem I've experience for the 8 months of driving it.
Good luck if you're having problems.
Old 02-23-2007 | 01:25 PM
rickremixx's Avatar
got car back today with new shifter should all be good now
Old 02-23-2007 | 02:07 PM
SoCalHHR's Avatar
It is a common problem - especially if you use the auto start, then forget to turn the key "on" when you get in the car!
The trans won't go into gear unless the key is turned to the "on" position.
I have a feeling many of these "reports" are from folks who have don the above.
Just throwin' it out there for folks to know...
Old 02-23-2007 | 06:19 PM
SandyBeach's Avatar
Absolutely, SoCal. Like a dummy, I did that the other morning. I used the remote start then got into the car and the button wouldn't depress. i was so glad I hadn't sold my old car because I used it to go to work. While driving, I was trying to figure out if it was a problem with the remote start. Then I remembered that I didn't turn the key. Glad I figured this all out before I called the dealer!
Old 02-24-2007 | 10:50 AM
GRUMPEE's Avatar
In my case, it was not autostart, I used the key to start the car. it would not get out of PARK.
rtp1511
2.4L Performance Tech
7
08-13-2013 11:48 PM
woodchuckd11
Maintenance and Upkeep
03-03-2011 01:48 AM
Hotrodbob
01-06-2010 07:51 PM
Geoff
09-08-2009 04:41 PM
Geoff
04-28-2009 12:58 AM
