Auxillary booster pump
Old 09-01-2010 | 06:42 AM
speedster's Avatar
lets see, now at least the 4th time coming up for the brake to the floor problem.. doesnt matter that it happened in their bay leaving the service dept and they witnessed the issue.. they want to "experience" the problem. i called the number chevy manager gave me and only dealt with the secretary and of course was steered back to my dealer.. they want it for another few days..bull crap...so somebody can take it home..i am done..maybe i will wait for a recall, my 1 yr anniversary just passed.. or i will sell it.
Old 09-01-2010 | 08:45 AM
HHRSSouth's Avatar
Is there no lemon law in your state?
Old 09-01-2010 | 01:05 PM
speedster's Avatar
yes there is.
Old 09-01-2010 | 03:29 PM
ChevyMgr's Avatar
Go to another dealer.
Old 09-01-2010 | 04:01 PM
ssbill's Avatar
i had a simliar problem with the braks on my ss i took it to chevrolet dealer 4 times.
complaint:brake peddle hard as a rock first stop am car has no power assist.after the 4th visit chevrolet came up with a repair add a vacuum pump to system to give brake booster vacuum.the had to add terminals to computer to run vacuum pump also had to wire in relay to fuse block and reprogram computer for pump.after getting vehicle back on 2nd day while passing another car turbo boost went past 30 psi and compter shut down turbo,no power now.took back to dealer kept vehicle 42 days waiting on turbo boost sensor.part came in was installed same problem.technican went back and rechecked all sensor connections went for test drive and problem was gone?????doesnt know hwat he did to fix it??? when dealer called chevrolet technical asst center no one there know anything about 2.0 tubo.???
Old 09-02-2010 | 06:27 AM
HHR_SS_QC's Avatar
I would find another dealer if I were you..
Old 09-10-2010 | 07:52 AM
speedster's Avatar
maybe i will..this issue has been from the start and documented. now since the car is a hair over the year old, i wont get a loaner car..nice.
Old 09-10-2010 | 08:10 AM
ChevyMgr's Avatar
If you are under 3 years old and 36K you do get a rent car.
Old 09-10-2010 | 09:15 AM
speedster's Avatar
i wonder why the service desk would tell me that. its 1 yr old with 5700 miles on it. the nearest dealer is 10 miles away, perhaps it might be wise to check them out.. i mentioned to the tech that i am not biting at the bit to have this pump installed [i dont want to bring on additional problems] but if thats the fix, no choice.
Old 09-18-2010 | 07:13 AM
speedster's Avatar
they had my car since tues morn..on thurs morn the issue happened for them..they determined the problem to be "the motor working the abs system" and the part needs to be ordered..so here i sit with this crappy corbolt.
Quick Reply: Auxillary booster pump
