Axle issue after accident.
"IF" it could be straightened out, they would still have to pull the axle out and put it on a jig to try and fix it. That would be the correct way to attempt a repair like that. Most shops would probably tell you it's cheaper and faster to just get a replacement.
I used to work in a repair/body shop. I've seen similar problems like this.
Find a replacement axle. Easier in the long run.
The bent axle beam is bent and to straighten it would require heat and pressure, this could weaken the steel , also the metal could flex and eventually crack at its weakest point, so a replacement used axle beam would be most prudent.
