Back of block
Old 01-04-2020 | 12:28 PM
Insulin_addict's Avatar
Got all the o rings out. The 2 round ones have some discoloration to them, I’m assuming from age. No nicks or apparent damage. Hopefully, they are just old and when the pipe got moved slightly from installing the exhaust manifold, it just did them in. New ones are ordered. Here is to hope.
Old 01-04-2020 | 12:34 PM
The bottom one is my guess for the leak. It isn't round anymore.
Old 01-04-2020 | 01:06 PM
Cat Man HHR's Avatar
Originally Posted by donbrew
DexCool is the recommended lube.
Murphy's is a lot slicker than anti-freeze.
But to each their own.
I bet GM installed everything dry.
Time is money.
Old 01-04-2020 | 07:49 PM
So once I lube the o rings, will I be able to feel them setting where they should in the water pump and the other side?
Old 01-05-2020 | 03:21 AM
From the video I posted, yes.
It's by feel a lot of the work because the exhaust manifold wasn't taken off.
Old 01-05-2020 | 07:14 AM
  #26
oh, I took the exhaust manifold off. I couldn’t imagine doing it with the manifold on.
Old 01-05-2020 | 08:24 AM
  #27
https://www.chevyhhr.net/forums/how-...acement-56476/ Is from the shop manual.
Old 01-05-2020 | 09:12 AM
  #28
OK now that we all know what you did as far as the exhaust manifold.
If the tube does't seat, lining up other parts will be off.
What did you lube the seals with ?
Old 01-05-2020 | 10:09 AM
  #29
nothing yet, parts are ordered and I am gonna put back together next week. I am going to use dex cool to live the rings with, as someone earlier said that’s what GM recommends.
Old 01-05-2020 | 10:45 AM
  #30
That was Don.
Defective
05-28-2018 05:28 PM
HighRoofLT
2.2L Performance Tech
0
12-01-2014 02:06 PM
10RedSS
2.0L Performance Tech
03-20-2011 07:42 PM
hhr_2009
02-03-2011 10:55 AM
Michael20832
02-20-2009 08:47 AM
Quick Reply: Back of block
