Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
For some reason my backup lights aren't coming on when I pop it into reverse. Bulbs are fine and so is the fuse. Is there a switch that may be bad on the Trans?
If its an automatic most likely its the neutral safety switch.
Could you expand on that? Thought the neutral safety switch is to only allow you to start the engine in Park or Neutral. Didn't think the reverse lights relayed through that switch.
FWIW. Visually check the wiring that goes to the transmission. Could be a loose wire or maybe just a bad connection. Maybe try unplugging and replug for a better connection. Can't hurt to try.
