Bad vibrations
Old 12-14-2009, 10:19 AM
retrofan's Avatar
Thanks for the head's up!!!
But should that not be a warranty issue??
retrofan is offline
Old 12-14-2009, 10:56 AM
pitbull76's Avatar
Only if you have an extended warranty. They are not covered by the powertrain warranty. You might be able to get goodwill assistance if it is the column but hopefully it's something simpler anyway.
pitbull76 is offline
Old 12-14-2009, 12:51 PM
ecl
ecl's Avatar
To reset the light you could also take the positive cable off the battery wait a couple seconds and then reinstall and you should be good. Done it many times.
ecl is offline
Old 12-14-2009, 04:15 PM
thedonn007's Avatar
Thanks for the tip, I had thought about that once too, then I forgot about it. So thanks for reminding me and for proving that it does work.
thedonn007 is offline
Old 12-17-2009, 04:37 PM
I'm not positive, but I'll bet the purge valve is part of the fuel pump in the fuel tank, which would explain the high cost.
donbrew is offline
Old 12-17-2009, 05:48 PM
oneton's Avatar
No it's not.
oneton is offline
Old 12-25-2009, 04:42 PM
Originally Posted by oneton
No it's not.
I am glad I did not have any money on that!!
Don
donbrew is offline
bobalouhill
04-25-2017 08:11 AM
2011hhr2011
10-14-2015 09:35 PM
SmootHHR
06-15-2011 01:34 PM
dark_islight
09-16-2009 06:07 PM
Goose
10-12-2007 04:18 AM
Quick Reply: Bad vibrations
