Battery Draw when Engine Running
Old 06-16-2022 | 11:50 AM
tr34's Avatar
Okay, I haven't driven the car since Friday, much longer than I had it sit for when the battery died (only had it sit over the weekend when it died). The battery is still okay, I have power to everything. Not sure what made the battery die before.
Old 06-16-2022 | 12:24 PM
greg8453's Avatar
You probably had a light on or you may have a bad switch. The switch can turn on or not turn off from door closing.
Old 06-16-2022 | 04:02 PM
The interior lights are "supposed" to go off automagically after 5 minutes after key removed & driver door closed.
Old 06-16-2022 | 04:09 PM
The radio stays energized for 10 minutes. As do the windows after the key is turned of but before the doors are opened.
RAP .. Retained auxiliary power.
Old 06-16-2022 | 07:53 PM
The interior lights are on a circuit that dims out, different from RAP but close. Fun to watch when you get home late.
MLDD
02-24-2022 09:49 PM
Cycara
05-21-2020 09:08 AM
venomlegionsHHR
06-09-2012 06:52 PM
Colin
04-26-2012 06:36 PM
Jeff'sHHR
09-28-2009 12:47 PM
Quick Reply: Battery Draw when Engine Running
