Battery Life
Old 12-19-2012 | 09:43 AM
solman98's Avatar
I replaced mine for piece of mind about a year or so ago. It was hard to start one day after sitting for a week. Today's cars rarely will give you the slow start as an early sign, they just don't start one day....
One thing nice about the stick, I can at least push start it....
Old 12-19-2012 | 07:08 PM
ChevyGrlAlways's Avatar
Originally Posted by ChevroletCustomerService
@ChevyGrlAlways, you can have the battery tested to help you make your decision.
I tried that...the machine just says that it is not connected to the battery...that is the only reading it gives
Old 12-20-2012 | 12:10 AM
Solman- yes you got that advantage with the stick shift,...
Was it connected to the undehood connections ? or on the actual battery by the spare tire ?
Old 12-20-2012 | 08:07 PM
They tried both, after 30 mins I said thanks and left, I give it to the guy, he kept trying, and was confused by it not reading
I think I am just gonna wait and let the battery go when it wants too
Old 12-21-2012 | 12:13 AM
ChevyGrlAlways-
That's a strange thing. Anyhow good luck on that..
Old 12-21-2012 | 11:20 AM
  #26
fastsuv's Avatar
I did that with my 1987 Mustang Gt 5 speed once. The battery had died overnight while parked in my garage. My driveway was about 100 feet long and sloped downward slightly toward the street. I started it rolling down the driveway, jumped in, popped the clutch and it started. Hope I don't have to do that with the HHR.
Steve
Old 12-23-2012 | 01:46 PM
  #27
Laco's Avatar
Hmm, odd, I had zero problems testing it, connected to the battery connections in back, not the under hood connections, though they should work too.
Old 12-23-2012 | 08:44 PM
  #28
db/sb's Avatar
Not sure what type of tool was used on ChevyGrlAlways' vehicle but I doubt if the underhood connections would give usable results with a conventional load tester due to the resistance caused by the distance those connections are from the battery. The test should be conducted with the tester connected directly to the battery.
Old 12-25-2012 | 12:50 PM
  #29
panelmoxie's Avatar
i forgot mine had a battery. It is four and 1/2 years old with 200,000 miles on it.
Old 12-25-2012 | 01:36 PM
  #30
Z-Man's Avatar
I guess I should think about replace mine soon after all its the one that came with my car when they made it in 2005, I have no problem but I think its time - Merry Christmas to all
Z-Man
Quick Reply: Battery Life
