Bluetooth- Problem Pairing
when i left the dealer my phone was paired and working. now it will no longer work (with Bluetooth). I tried to pair it again, several times and my phone keeps telling me that GM can't be set up as a trusted device.
Did the original pairing involve entering a GM code? If not the phone is not compatable. A non compatable phone can be paired with limited functions but usually craps out after a while.
Push your button, say bluetooth, say delete. If the original paired phone is there the system will state the name. If it is delete it. Then try to pair again.
If you entered the GM code and it still wont work then the system has a problem, take it to the dealer.
thanks everyone. my phone died. so I have been using my wifes old piece o'poop Treo until my upgrade. I ended up doing a hard reset twice and it worked. it just let me enter the GM code, so as of now they are paired again.
maybe the phone DOES know something I don't.
I paired both mine and wifes phone. Mine has never had issues hers on the other hand, well the phone is stupid at times. One time the phone no longer was connected and I had to redo it. Now it shows on the phone it is conected but the ss can't seem to find it. Kept trying to call w/ onstar. I then get in and works fine w/ my phone. So I know it is the phone not the car.
