Brake & Cruise Switch Adjustments
Old 10-19-2020 | 07:31 PM
Originally Posted by jjoverit
I did not see any bushing. I just replaced my switch. Sometimes you have to slam on the brakes a few times then cruise will work. Ac delco part also
Your 2010 does not use a switch like oldracer's 2007. Yours has a BPP sensor(brake pedal position). The new sensor may need to be learned.
Old 10-19-2020 | 07:38 PM
jjoverit's Avatar
Intermittent cruise control
I have a 2008 ls now. Need to change that in profile
I bought the new switch its plastic with 2 plastic prongs on it. Its held in by one bolt and a nub that goes into hole. But the plastic prongs went around a metal stud that comes off of the pedal. Is there a small bushing that goes on the stud?
Old 10-19-2020 | 09:12 PM
Thread died in 2013.
Check you center brake light one or more of the bulbs might be intermittent.
Old 10-19-2020 | 10:13 PM
Does it look like this?
Further research indicates that the 2008 model year is when the change from switch, to the sensor, was made. So you should have the sensor pictured above. No bushing.
Old 10-19-2020 | 11:10 PM
jjoverit's Avatar
yes. I changed that and it's still acting funny. Sometimes it works other times I have to slam on the brakes a couple times.then it will work
Old 10-20-2020 | 06:11 AM
Sounds like a poor connection. Check the wiring.
Old 10-20-2020 | 08:13 AM
Do the brake lights work when this happens? The cruise control will not work if the third brake light is not fully functional.
Old 10-20-2020 | 11:35 AM
jjoverit, I’ve updated the year of your HHR , is it an LS or 1LT Or 2LT 2.2 or 2.4 ?
I’ll fix that for you too
Old 10-20-2020 | 11:03 PM
jjoverit's Avatar
it is a 2008 ls with a 2.2
thank you I wrecked my 2010 so i got another.
Old 10-21-2020 | 05:25 AM
Fixed, thanks for the follow up, sad about your 2010!
Quick Reply: Brake & Cruise Switch Adjustments
