Brake pedal relay click??
Old 02-08-2012 | 04:32 PM
Felony's Avatar
Question Brake pedal relay click??
I feel foolish in asking this, after 2yrs you would think I know this but; when the car is idling in park and you just lightly press the brake pedal, there is a noticeable relay click sound coming from the interior fuse panel. When in gear, forward or reverse, using the brake pedal does not produce this click. Is this normal, have I've always heard this? The car has been sitting for 3 wks while I gradually install two rear view cameras and I just started the car up today. First the brake pedal was mushy, but after riding a bit, that went away. That's when I noticed the loud clicking while testing the pedal for firmness. I'll post up pics of the camera install when I get a chance. Thanks for any replies.
Old 02-08-2012 | 04:55 PM
That's part of the "Brake Shift Interlock" system you're hearing, absolutely normal, you won't hear it unless the shifter is in Park.
A mushy feel to the brakes can be caused by corrosion on the friction surfaces, sitting for three weeks is enough time to build up some surface rust and make the brakes feel "odd" until the pads and shoes burnish it off.
Old 02-08-2012 | 04:56 PM
Normal. It's the brake/shift interlock solenoid.Not sure of the proper name.
It is the safety feature that keeps you from shifting out of PARK until the brake is depressed.
Old 02-08-2012 | 04:57 PM
Come on Mike. I think we were typing at the same time.
Great minds think alike ya know.
Old 02-08-2012 | 05:10 PM
Felony's Avatar
Are you sure you're not twins separated from birth? Thanks for the quick replies. I guess I got accustomed to the sound and then had a reawakening after the layoff period. I must be getting old. Ugh.
Old 02-08-2012 | 09:55 PM
Felony- You're not alone... I never heard that click for quite a while either..
https://www.chevyhhr.net/forums/general-hhr-4/clicking-sound-when-hit-brakes-park-only-33027/
Old 01-06-2016 | 07:44 AM
scbill's Avatar
Bringing up an old post,but....Mine has started to click in all positions, it did this once before with a code(don't remember the #s) cleared the OBD, all problems went away. Yesterday it started doing it again, trans shifted hard for a few miles, then went to shifting normal. No codes this time, still clicking in all shift positions. Any ideas please.
Thanks Bill
Old 01-06-2016 | 08:11 AM
The interlock at the shifter could be getting dry and dirty, pop the shifter cover off and give it a shot of spray lube.
Old 01-06-2016 | 08:13 AM
scbill. You've got 2 different issues going on. The shift detent solenoid in the console may be fixing to fail.
The hard shifting is most likely the result of the CEL. Need to identify the CEL number and correct that cause.
It's doubtful that the 2 issues are related or affect one another.
Quick Reply: Brake pedal relay click??
