Brakes making a grinding noise
Okay people, I really appreciate the help. I mean that, but here is what I have done the past couple of days. I am getting this chirping noise from my front driver's side wheel when ever I turn to the left. It doesn't do it all the time, it seems to get worse the longer I drive. And I also noticed when I apply the brake or turn back to the right, it stops. I took everything apart, greased the slide pins, greased around the caliper piston and reassembled everything and made sure everything was nice and tight. I also put on new rotors. The clunking/grinding noise has stopped, but I am getting this squeaky, chirping noise as I mentioned. Also, I sprayed the car off yesterday. I have custom wheels on it so I can clearly see the rotors. When I sprayed the driver's side, the water started sizzling as soon as it hit the rotor. The passenger side was hot as well, but nothing like the driver's side. My father-in-law thinks it could be the bearings and not the brake, but from what I have seen and read, bearings make more of a grumbling noise. This is a definite chirp chirp chirp and gets louder when I'm turning. Again, I really appreciate everyone's help.
Why would any body apply ANY grease to the pistons of a NEW caliper?
Yes. hubs, LCAs, brake wear indicators all make noises (many only when turning). Could the "chirp" be better described as a "click", then CV could be the problem. Bearings/hubs make so many different kinds of noises, don't even ....
Not replacing BOTH sets of pads could also be a problem.
Hi colzdad,
I’m sorry to hear that you are experiencing this problem with your brakes. Please feel free to reach out to us of you would like for us to take a further look into this. We can be reached via private message if any extra assistance is needed. Please reference this thread in the message. Thank you.
Kristen A.
Chevrolet Customer Care
Kristen A.
