brand new hhr steering problem
Old 07-07-2008 | 06:14 PM
gunner72's Avatar
hi, Just bought my hhr one week ago. I was pulling out of a parking spot when i discovered i had no steering, the steering wheel would not move! A light came on that said 'service air bag" after waiting for the wonderful chevy roadside assistance for an hour and 40 minutes I decided to try the car again which then the steering was fine, go figure and drove it to the dealer myself. Anyone have any ideas. I can't believe this is a brand new car and this going on. Very dissapointing.
Old 07-07-2008 | 06:23 PM
ChevyMgr's Avatar
Without knowing what codes were set, it is nearly impossible to help you on this issue. May be programming, wiring problem or BCM problems.
Old 07-07-2008 | 06:26 PM
gunner72's Avatar
what do you mean by codes?
Old 07-07-2008 | 06:35 PM
1stTimerHHR's Avatar
could it possibly be the 'ole loose fuse problem rearing its ugly head?? Check and push in the fuses in the fuse box under the hood?
Old 07-07-2008 | 06:48 PM
ChevyMgr's Avatar
Anytime the BCM (Body Control Module) commands a warning message or light to appear on your instrument cluster or the DIC, it sets a code, which is stored by the BCM. With this code diagnostics can be performed to find out why the code was set.
Okay for 9 months I have remained silent on this one but today I give my take on it. This is an Urban Legend that as far as I can tell, was started on this forum. Any correlation between pushing on fuses and a symptom disappearing is purely coincidental. As stated by the OP, turning the vehicle off and back on will have better results then pushing on fuses.
I have never heard or seen this fixing any car for any reason. Now I feel better, so if you want to dispute me, go ahead. I'm all smiles as I type this.
Old 07-07-2008 | 07:17 PM
an08HHR's Avatar
I lick my finger first and press the fuses and then the tingling means they are set proper. Works on house current also. and after 9 months I wake from a coma
Old 07-07-2008 | 08:12 PM
stick's Avatar
Let us know next time you are going to do that, so we can "borrow" your HHR since you won't be needing it
mike321
03-05-2014 10:59 PM
probablecause
02-26-2010 07:18 AM
tcstoy
03-09-2008 12:50 PM
ithak54
01-12-2008 08:26 PM
Quick Reply: brand new hhr steering problem
