A/C sometimes work...
Old 05-05-2014 | 06:09 PM
HHRtrucker's Avatar
Question A/C sometimes work...
Hi everybody!
This is my first post and I'll really appreciate your help.
I have a 2006 HHR LS 2.2 the last summer A/C worked perfect cooling very well even in idle, but this year it has been working intermittent blowing hot air sometimes, it colds good when car is accelerated running at least 2500 rpm.
I've checked gas pressure and it's 40 psi on the low side and 250 on the high side, I got to add more gas and have higher pressure so it can cold but still getting hot air on engine idling, could it be the expansion valve?
As an additional information the weather was 90 degrees and 5% humidity...
Old 05-05-2014 | 08:13 PM
I will bet that your coolant temp is running around 170F, and you have a Check Engine Light. If neither of those then check your coolant level. You probably need a new Thermostat.
Old 05-05-2014 | 10:06 PM
Lucky's Avatar
Welcome to the site
Your symptoms don't sound like an expansion valve. I would reclaim the r134 and recharge to the proper weight then recheck your output temperature.
Old 05-06-2014 | 07:58 AM
X2 from Lucky!!
Jeffharden1
08-25-2014 01:50 PM
whitelightnin
05-09-2012 09:15 PM
mycv8z
Tires & Wheels
04-14-2012 09:07 PM
Hotshotfxdl
10-01-2010 08:47 PM
sargechris
09-09-2008 08:48 AM
Quick Reply: A/C sometimes work...
