Camphaser spring mix up.
Hi there,
This is my first thread, I am Jacob and live on Curacao N.A.
My water pump was leaking and I had no tool to hold it so I took away the timing chain cover.
Inside I found a lot of sludge, so I removed the camshaft cover to and clean this mess.
I also disassemble the cam phasers but I am not sure witch spring belongs in witch phaser..
One of them is longer, I order a new timing chain kit with phasers but this can take over 6 weeks.
I need to drive it so I have to do the job two times.
Sorry for any mistakes in my writing.
I hope someone can help me.
With kind regards.
Jacob.
With kind regards.
Jacob.
I know what you meant, I have never heard of anyone taking them apart, The shop manual says they are not repairable.
BTW; they are called "actuator, camshaft position" , Ford calls theirs phasers, they are a different thing, but do the same thing.
If the sludge was that bad, how could the VVT work? I imagine the Check Engine Light was being ignored for a very long time. Cheaper to change the oil regularly.
# donbrew, I bought the car recently and I change the oil but no indication off sludge.
The engine light was burning and also the TC and ABS lights. a gay did a computer check but did only reset the computer.
Now I bought myself a scan tool and now I now the codes, I did order a complete timing chain kit but this takes over 6 weeks to get it here.
I realy don't now if the actuators where working because of the poor maintenance by the last owner.
I found the performance of the car very poor, I hope for better performance if everything is ready.
