Camphaser spring mix up.
Old 01-12-2018 | 01:29 PM
Jacob van Zwol.'s Avatar
Hi there,
This is my first thread, I am Jacob and live on Curacao N.A.
My water pump was leaking and I had no tool to hold it so I took away the timing chain cover.
Inside I found a lot of sludge, so I removed the camshaft cover to and clean this mess.
I also disassemble the cam phasers but I am not sure witch spring belongs in witch phaser..
One of them is longer, I order a new timing chain kit with phasers but this can take over 6 weeks.
I need to drive it so I have to do the job two times.
Sorry for any mistakes in my writing.
I hope someone can help me.
With kind regards.
Jacob.
Old 01-12-2018 | 01:41 PM
I don't think the phasers are made to be taken apart. There are no instructions in the service manual.
Old 01-12-2018 | 02:23 PM
Welcome to the site, nope the solenoids are not to be disassembled.
You have a 50/50 chance if putting them back together correctly
Old 01-14-2018 | 02:51 PM
Thanks Oldblue, its very easy to take them apart. I had to do it because of the sludge in my engine.
I reassemble them and see what happens, it seems nobody on the forum has taken these apart.
Old 01-14-2018 | 02:54 PM
That because they are easy to replace , so why take them apart?
Old 01-14-2018 | 02:58 PM
Thanks donbrew, not the solenoids bud de phacers, you can take them apart for cleaning.
Old 01-14-2018 | 03:02 PM
I live on Curacao, I need the car to drive. Between ordering and getting my parts takes over 6 weeks.
Old 01-14-2018 | 03:10 PM
I’m Canadian and frugal, so I bought an 07 2.2 so it doesn’t have VVT Solenoids .
Old 01-14-2018 | 05:09 PM
I know what you meant, I have never heard of anyone taking them apart, The shop manual says they are not repairable.
BTW; they are called "actuator, camshaft position" , Ford calls theirs phasers, they are a different thing, but do the same thing.
If the sludge was that bad, how could the VVT work? I imagine the Check Engine Light was being ignored for a very long time. Cheaper to change the oil regularly.
Old 01-15-2018 | 06:34 AM
# donbrew, I bought the car recently and I change the oil but no indication off sludge.
The engine light was burning and also the TC and ABS lights. a gay did a computer check but did only reset the computer.
Now I bought myself a scan tool and now I now the codes, I did order a complete timing chain kit but this takes over 6 weeks to get it here.
I realy don't now if the actuators where working because of the poor maintenance by the last owner.
I found the performance of the car very poor, I hope for better performance if everything is ready.
Quick Reply: Camphaser spring mix up.
