Car is creaking like crazy, looking for things to check (have researched here already
Old 07-29-2019 | 08:27 PM
Originally Posted by Silverfox
85,000 miles ....You might also want to consider replacing replace the End Links with Moog Parts.
They have zerk fittings that can be greased.
Silverfox
X2. The end links are attached to the end of the sway bar, and typically don't last a long time.
Old 07-29-2019 | 09:23 PM
Jpak88's Avatar
85,000 miles ....You might also want to consider replacing the End Links with Moog Parts.
Silverfox
Already got'em :) had them for a while
Old 07-30-2019 | 05:50 AM
Lethal Tendencies's Avatar
What brand of Struts were installed. I had some cheap ones put on my '08 LT years ago and those things creaked for months.
Old 07-30-2019 | 09:11 AM
Jpak88's Avatar
I honestly don't know, I didn't think to ask. I wouldn't call the job that got done "cheap" though. It was over $700 parts and labor at Tire Discounters. Now I'm dreading the replies that they are a bad company and install crappy parts.
Old 07-30-2019 | 11:25 AM
It should specify which brand on your invoice or work order. The HHR OEM I think where from Sachs.
Old 07-30-2019 | 12:11 PM
Jpak88's Avatar
I couldn't find my invoice, the guy on the phone looked it up but he said it didn't say :/ he mentioned Monroe, I asked if it was OEM and he said probably not.
Update : called back at spoke to the manager that oversaw my actual repair. He said it was proba ly either Monroe or it could've been FCS. But they've got good warranties on parts and labor for this work so if the bushings don't help I'll bring it back there. He also said they replace mounts on all cars older than 10 yrs so that got done too.
Old 07-30-2019 | 12:30 PM
Jpak88's Avatar
Well guys, other than the question of the brand of struts, you guys have made me feel a lot more confident about it being the sway bar bushings. I really appreciate how nice and informative you always are. I'm taking it in tomorrow, I'll update then!
Old 07-31-2019 | 03:58 PM
Jpak88's Avatar
Update, so he ordered the wrong bushings because I apparently have an SS sway bar on my LT. I didn't know that could be a thing. Anyways, they played with the sway bar but it seemed okay enough (will still replace them soon) but they noticed that the ball joints were really dry and making noise so they greased them up nice and good.
The noise is so far gone but I'm not holding my breath. The car is always quiet for the first couple days off his rack, so fingers crossed. There's definitely a squeaky creak in the rear too but it's far less insane than the front so I'm not too pressed on it.
Anyway long story short, it may have been the ball joints.
Old 07-31-2019 | 04:31 PM
You have a 2006 , they came with 23 mm diameter bars up front.
It could just be the ball joints, I grease mine every 3,000 miles.
Old 07-31-2019 | 04:46 PM
Jpak88's Avatar
What do all the others have in terms of diameter? And I think it was both, it's still creaking a little bit but not nearly as aggressively. I'll check it out at my next oil change.
Quick Reply: Car is creaking like crazy, looking for things to check (have researched here already
