Car does nothing...
Car does nothing...
Ok here is the deal, bascically nothing is working in my hhr, power locks dont work, lights inside and out do not work, car does nothing when i turn my key, etc etc.
I checked every fuse and relay, unhooked and cleaned and rehooked the battery cables, but still nothing, im not sure if it is my alternator or not, is it possible i have a short in the wiring somewhere?
I had it jump started a couple of times and everything worked for about 5 hours then the car goes back to being dead, had the battery checked by 3 different autoshops and there was no problems with it.
Any suggestions would be appreciated.
Thanks, Justin
Thanks, Justin
So the battery is now dead and nothing electrical works because of that....correct? You have checked the battery when nothing is working and you get what result? If the battery is dead, you can only assume the battery is getting no charge from the alternator OR/AND the battery is not holding a charge......maybe with the battery as the culprit. Can you switch the battery with another vehicle and try that for a day or two. If the battery is "killed" then obviously the alternator is at fault. Of course, you could have the alternator checked for output as well. I think places like Auto Zone may do this with no fee.
Bottom line....you need to determine if the battery is dead WHEN THE CAR WILL NOT START AND WHEN YOU HAVE NO POWER TO THE OTHER ELECTRICAL ITEMS. IF it has better than 12.2-12.3 volts it may be an electrical connection from the battery to the BCM AND the ECM.
Dead HHR
I have had this problem twice and I am convinced it has to do with the anti theft......you put your key in...all the lights come on etc....but nothing happens when you crank it....I had trouble even getting the key out afterwards!! very weird.......locked it up...called the Auto club for a boost....fired right up and no trouble since.....
@MikeMacbeth, I have read your post; I can imagine the frustration that you must have been going through with this. I am glad to read that you are no longer experiencing this. What is the year of your HHR?
I hope you have a great weekend.
