Car overheats when A/C is running.
Old 07-26-2015 | 08:37 PM
paullleor's Avatar
My 2008 HHR overheats sometimes when the A/C is running. Add soon as I turn the A/C off it starts cooling down and running at normal temp. Also once the A/C is turned off there is a noise from under the hood. Not sure how to describe it. The coolant level is good. There are no signs of any leaks. The air does get cold when it isworking. But gets hot once the car hits cooling mode. It's been making the noise longer than the over heating. The fan also stays on one the car is off sometimes. Thanks in advance.
Old 07-26-2015 | 08:46 PM
Have you checked the other obvious items:
- coolant level correct?
- does the rad fan(s) come on as soon as the a/c is switched on?
And can you describe what leads you to think it is overheating? What does the digital temp display read at normal (without A/C on), and once the A/C is on and it starts to overhead?
Old 07-26-2015 | 08:50 PM
paullleor's Avatar
The display shows the temp at 260. The fan does come on when I turn on the A/C
Old 07-26-2015 | 08:51 PM
paullleor's Avatar
When ac is off it reads 200-210
Old 07-26-2015 | 08:53 PM
Old 07-26-2015 | 08:55 PM
paullleor's Avatar
Yes. And the noise isn't the noise like a water pump or bad pulley, belt
Old 07-26-2015 | 09:08 PM
Is the noise constant when the engine is running, or only when the A/C is on?
(sorry, got hung up with a couple phone calls)
Old 07-26-2015 | 09:15 PM
Here's an interesting thread about a noisy water pump - https://www.chevyhhr.net/forums/prob...mp-gone-26225/
Old 07-26-2015 | 09:17 PM
paullleor's Avatar
It's constant when ac is off. Thanks I will look at the link.
Old 07-26-2015 | 09:28 PM
Old-school trick to isolate the source of a noise internal to the engine: grab a BIG ol screwdriver, hold the end of the handle tight to your ear, and put the tip of the screwdriver tight against the engine here and there - it will help pinpoint the area where the noise is coming from. Of course you have to be careful where you place the tip. Might be a helpful way to diagnose a water-pump issue.
If it is only when the A/C is off, I'd suspect the clutch in the A/C, belt or tensioners. But I don't see how they would be related to it overheating.
Quick Reply: Car overheats when A/C is running.
