Car won't start
I installed a Sony radio following the wire diagram and now my car won't start, I've check all fuses and the car seems to be in security lock and have tried the relearn with no success
try disconnecting the battery (you call it a lobotomy).
If it doesn't help, then computer diagnostics.
Maybe, when installing the radio, you accidentally made a short circuit and something turned off in the onboard brain or in the alarm control unit. By the way, the alarm is connected to the head unit.
But start with a lobotomy.
I also gave that a try, you mentioned that the alarm goes through the radio. I have a base model with no controls on the steering wheel so will I need to install an interface as well. I have had someone hook up a diagnostic to it and clearing the codes didn't work either
I got the wiring diagram off of this site, and I wired it direct and used the switch source for the sunroof at the fuse block ,"which I don't have a sunroof
You could use any of the "spare" fuse positions in the BCM fuse box' they are switched and delayed (RAP).
Security does not prevent cranking. The lock&key will light up if the battery is dead or disconnected. Maybe you disturbed one of the red wires on the BCM.
I can't think of anything that a normal install could do to the starter. Unless the car has OnStar and you did something to that wiring.
Check Fuses #8, 10, 16, 24 and 25 on the BCM.
