car won't start or crank after shift solenoid replacement
Hello I just finished getting my car back together after replacing the 4 trans solenoids. Everything is pluged back in except the shift cable retainer (pics below) and after filling the trans with about 5-6 quarts of transmission fluid, the car will not start and I'm fairly sure I still have a check engine light. I didn't take apart the fuse box just removed the four bolts on the side and bungee corded it out of the way and I reconnected the ecm and computer before connecting the battery. I'm going to try and jump start it but other than that I'm clueless.
Turning the key to on
Turning the key all the way to start
Shift cable
Update: car is stuck in neutral I think
Update #2: car is stuck in neutral even though shifter is in park
I also ripped the front wheel well when lowering the car but that can be dealt with later. FML
Shift cable
MrTopgun21
Drivetrain (Excluding Engine)
07-13-2021 05:36 PM
charhhr06
09-12-2013 03:58 PM
