Changed Rims/Tires for Winter and now have a Service Tire Pressure Sensor Warning
Not sure if this is anything I should worry about but I recently changed out my Rims and Tires for winter on my 2008 HHR SS and the next day I got a Service Warning on my Dash about the Tire Pressure Sensors.
To be honest I am not even sure how the Tire Pressure Monitor Sensors even work. Is there something in the RIM that does that or what? I hope it is nothing to worry about and all I have to put up with is acknowledging the warning until I put my regular rims/tires back on after winter.
On a TPMS the air valves are sensors and they need to be programmed to the system when wheels are changed or even rotated. Either the winter wheels don't have the special valves or they just need to be set to the system.
Forgive me but I do not know that. I bought these rims and tires off of a friend that has Cobalt SS and since he moved down South he no longer needed them. I am not even sure if the Cobalt SS (2009) had TPMs on the car.
How can I check the valve stems on these other sets of tires or what can I do to program them. Probably something that needs to be done at the dealer too or with a programmer.
You think if I just deal with the annoyance for a few months and when I put my stock rims back on it will be OK aside from maybe needing an adjustment in programming?
Thanks for all your replies everybody.
Thanks for all your help and information.
Now that they have tire pressure sensors on many cars, Michelin is about ready to market the Tweel.
http://www.fastcoolcars.com/airless-tires.htm
