Charging battery
Charging battery
2008 HHR SS. When charging an HHR battery is there anything special that needs to be done? Anything that should be disconnected first or can I just connect my charger to the pos and neg posts and go from there?
I had to disconnect my battery and bring it in to charge it but mostly because it was so blame cold outside. The battery was frozen and needed to be thawed out first otherwise I would have left it in the car.
I used the underhood location and put it on a 6 amp charger for about 2 hrs and it started fine. I now have it on a trickle charger and will leave it overnight to, hopefully, get a more complete charge. I don't know how old the battery is but it appears to be an original-tpe AC Delco 90-6YR unit. I've had the car since Sept of 2013 so maybe it's time to shop for a battery. just to be safe.
junker
07-26-2016 10:16 AM
kmcrae476
05-25-2015 11:19 PM
