Check Engine Light
Old 09-08-2006 | 01:16 AM
trey1966's Avatar
i checked all the regular stuff the manual said to check and nothing seemed to shut it up. the dealers service dept opens before autozone does, so I am going to drive across the street and have them scan it real quick and tell me what's going on. If it's something I can fix, I would rather do it only to get the know the car better, but it could be out of my hands.
Old 09-08-2006 | 07:05 AM
SCOOT's Avatar
Trey... Don't think you can use the 'jump-pin' approach on these vehicles, as (I believe) that could only be done on OBD-I vehicles (trust me- been there a LOT with my '95 Probe GT).
Sounds to me like you might have a possible (air) leak. Double check everything's seated properly and fully. Otherwise you may have (mysteriously) fouled a plug or something (injector?). Just mentioning these from others that have had CEL's thrown recently.
Worst case scenario- put the OEM unit back on and see if it disappears! My feelings are it wont, as only the MAF sensor was the only thing that you really 'touched'. Speaking of which... make sure that harness is plugged in 100%.
Good Luck and keep us posted...
Old 09-08-2006 | 12:07 PM
trey1966's Avatar
Dealer called. Misfire code. I get a rental for a couple of days...
Old 09-08-2006 | 12:36 PM
SoCalHHR's Avatar
It was probably just from triggering the fuel shutoff/rev limiter.
I would just slap a new set of plugs in there and get a reset.
Ask your dealer to put the Bosch plugs in!
Old 09-08-2006 | 04:36 PM
trey1966's Avatar
I called the dealer to see if could get some more information, and they said that took it over the tune up/drivability guys and they did some electrical diagnostics, and couldnt find anything wrong, so now its headed over to the line to have the mechanics check it out. I asked them to throw some new Bosch plugs in for the hell of it and they said no problem, but that "shouldn't" be the problem. So in my eyes, they still don't know whats wrong...
Old 09-08-2006 | 04:38 PM
SoCalHHR's Avatar
Most dealers don't know what's wrong when you take an HHR in!
Old 09-08-2006 | 04:42 PM
JimZ_HHR's Avatar
I was just at the Dealer... seen your ride sitting there...i Hope it's all fixed and ready to go for you.... got an appt. monday for leaking sunroof.
Old 09-08-2006 | 04:46 PM
trey1966's Avatar
Oh well, just going to have to wait it out till Monday I am told.
The rental is a freaking huge Silverado 4 door which is eating gas...not to mention it doesn't fit in my parking spot at my condo, so I have to park down the street...
Needless to say the girlfriend says it's my fault for, "pushing that cute little car to hard." One of these days sweetie, one of these days...
Old 09-08-2006 | 04:53 PM
trey1966's Avatar
Yea, the poor thing is just sitting in the heat as they stand around wondering what is wrong ...
Old 09-08-2006 | 08:29 PM
DARK AGE 53's Avatar
I've been reading your thread and I'm not clear on a few thing, did you miss a shift and was it running fine when you took it to the dealer..BTW, I can't see putting in new plugs will help any....but it's your money.
Quick Reply: Check Engine Light
