View Poll Results: What should I do with the 2007 HHR
Buy new engine
0
0%
Replace crank shaft bearing
0
0%
Rebuild engine
0
0%
Get out while i am ahead(-5509$) not quite ahead
0
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Chevy HHR 2007 tach broke crank sensor
Old 11-04-2023, 07:58 AM
The code causing the CEL will tell what the problem is. That is the reason it exists.
The reluctor ring is a hunk i=of metal with teeth on the edge. I don't know how it could be damaged without intent. I guess sticking a screw driver into the sensor hole while the engine is running could do it or a bad rebuild job.
A new crankshaft sensor requires programming. That would cause a P0315 sensor variation not learned. Usually only happens when the ECM is replaced. It means a blank spot in the data. Usually does not cause obvious problems.
P0324-P0336 have to do with the sensor and its circuitry.
My choice is not in the poll. I would consider some legal actions.
donbrew is offline
Old 11-04-2023, 06:26 PM
PulpFriction's Avatar
Heartbreaking victimization by inept or larcenous mechanics.
PulpFriction is offline
Chrris F
2.2L Performance Tech
7
06-26-2019 03:08 AM
mr chevelle
02-19-2013 06:02 PM
68 redrat
11-20-2012 09:35 PM
saturnsw2
03-24-2012 03:45 PM
sndsgood
04-30-2011 07:18 PM
Quick Reply: Chevy HHR 2007 tach broke crank sensor
