Climate Control Vent Selector
Old 05-01-2022 | 11:50 PM
Clevenger87's Avatar
Originally Posted by greg8453
Did you do the reset?
I did the reset this afternoon and it seems to have fixed it. I will drive it for a few days and let you know if the problem persists. Thanks everyone for the advice!
Old 05-03-2022 | 10:39 AM
I was driving last night and it started acting up again. I had the defrost on and all the sudden air started coming out of the front dash and the selector knob was unresponsive.
Since the reset seemed to go through all the vents I think the motors might all be ok. Maybe it's an issue with the climate control panel?
I also just changed the cabin air filter right after I bought the car. Is there anything I could have messed up while replacing that?
Old 05-03-2022 | 11:11 AM
Only if you didn't put the filter in the slot or stuck something in the hole.
The control panel is very easy to replace. stick your fingers in the vents and yank to remove the "waterfall" then 2 screws and the electrical connector.
Removing a stock radio - Chevy HHR Network
Old 05-03-2022 | 01:51 PM
Thanks! I'll try pulling the control panel and see if I can find anything wrong with it.
Old 05-03-2022 | 05:04 PM
greg8453's Avatar
It sounds like the control module is having issues. Need a factory level scan tool to see what is going on.
Old 05-03-2022 | 06:04 PM
Thanks! I can pull one from the junkyard and give it a try. Do you know if they have to be programmed to the vehicle?
Old 05-03-2022 | 06:32 PM
I’ve only replaced one, it was plug and play.
Clyde
07-26-2021 04:03 PM
PaperChaseHHR
10-08-2013 04:22 AM
ardblo
09-20-2013 02:03 PM
dustindell
12-08-2010 10:21 AM
Remford
11-05-2009 11:24 AM
Quick Reply: Climate Control Vent Selector
