Code P2270
There are several reasons
Exhaust leak near O2 sensor
Contaminated or failed HO2S2 (Sensor 2)
HO2S2 wiring/circuit problem
Loose installation of HO2S2
Fuel pressure incorrect
Faulty fuel injector
Engine coolant leak
Faulty purge solenoid valve
PCM has failed
You can rent a fuel pressure tester at most auto parts palaces. That’s where I would start
Engine coolant leak
PCM has failed
I agree with sparing the parts cannon.
There are a few cases, tho, where you can save the list of other possibilities for the unlikely event that ridiculously common cause isn't it.
Like P0010/13; check the wires, but it's almost always a bad solenoid section of the VVT solenoid valve. Yeah, you could check the resistance, prolly pointlessly...
