Codes p0030, p0033, and p0135
I have a 2006 HHR w/2.4 engine. I'm getting check engine light w/codes p0030, p0033, and p0135. Disconnected battery but codes came back. I checked the fuses, can't find blown fuse. The problem seems to have no effect on performance. Any sujections will be greatly appreciated.
P0030 HO2S Heater Control Circuit Sensor 1
P0033 Turbocharger Bypass Valve Solenoid Control Circuit
P0135 HO2S Heater Performance Sensor 1
Ok now I'm confused, did the 2.4 have a turbo in 2006? heater control and performance sensors?
the O2 sensors are heated and they could trip the code s P0030 and P0135.
I'm sure one of us will have some answers. meanwhile check for loose wires and fuse box under the hood
I Googled "P0135" and got:
http://www.google.com/url?sa=t&rct=j...59026428,d.cWc
And P0030:
And 9 threads on the first page using the SEARCH box. "p0135" Cut n' paste it.
Since everyone wants me to do the Googling. That's $1,530 please.
And P0030:
Check the wiring to the 02 sensor if all ok and fuses are good then replace the 02 sensor. Sensor number one is the one before the cat. Convertor. I don't no about the turbo code it may just be a glitch it the code reader.
