Condenser blown- still under warranty but not paying because it was a rock
Old 10-16-2009, 05:22 PM
HHRmobile's Avatar
I took my 2007 HHR to the dealership to get a repair- the ac had stopped working and I didn't know They said it was a rock that had cracked the condenser and it would be $862, it would not be covered under the warranty since it was road damage. I told them that there were a lot of instances of this happening, and they said there was a gm satisfaction warranty that it might be covered under. So I've been fighting w/ GM ever since. I was driving on an interstate not off roading or anything- what are the condensers made out of that a rock will just crack it? If I thought the warranty wouldn't be upheld I would've never went to the dealership in the first place. I've seen the TSB that addresses the grill put in to protect this. Is there anything else I can use to get GM to see it is a manufacturing flaw to have the condenser open to the elements and cover the repairs?
HHRmobile is offline
Old 10-16-2009, 05:38 PM
ChevyMgr's Avatar
Sounds like you covered all the bases on trying to get them to cover it. Have you seen where the damage is? I am thinking it's not a crack but rather a hole in the fin area.
ChevyMgr is offline
Old 10-16-2009, 06:46 PM
unique_w's Avatar
Condenser
Originally Posted by HHRmobile
IThey said it was a rock that had cracked the condenser
Curious, do you have a lower bumper grille or wire mesh installed ?
There are OEM condensers on eBay for about $250 and OE replacements for as low as $90
just a thought.
unique_w is offline
Old 10-16-2009, 07:47 PM
MONZA679's Avatar
A rock dented the bottom flew of my radiator and it started to leak. I called the dealer and it was over 400.00 for a radiator. I bought a aftermarket unit for 150.00. Bolted up fine has been installed for about 8k now.
MONZA679 is offline
Old 10-16-2009, 11:25 PM
mistermike's Avatar
Condensers and radiators are made of aluminum. Rocks are much harder. There is nothing GM could have done differently to prevent a rock from causing damage. Buy a replacement condenser and have a reputable A/C shop swap it out.
mistermike is offline
Old 10-16-2009, 11:30 PM
prod's Avatar
Actually there is a TSB to add a plastic protector to the front isnt there?
Do you have the black plastic grid covering the exposed area of the coil?
prod is offline
Old 10-17-2009, 04:14 AM
41pontiac's Avatar
Call your insurance rep, it should be under your comp. policy!!
41pontiac is offline
Old 10-17-2009, 04:33 AM
Stryker's Avatar
Which more than likely has a $250 or $500 deductible when the cost of the repair if he gets an aftermarket part will be less than this anyway :)
Plus making a claim could increase his insurance even more
Stryker is offline
Old 10-17-2009, 07:21 AM
Tominator's Avatar
Remember to replace the receiver dryer along with the condenser. Once exposed to air for any length of time they are toast.
Tominator is offline
Old 10-17-2009, 08:58 AM
bigdog9586's Avatar
Should be covered by insurance and come under the part that they don't raise the rates for unlike if you have a wreck.
bigdog9586 is offline
Quick Reply: Condenser blown- still under warranty but not paying because it was a rock
