Control arm bushings. Which side up?
Front lower control arm bushings. Was about to pop these after markets in and noticed there’s a difference. There’s no dot to line up on either side. Theres a series of numbers on one side but no dot. And one side is ribbed. So which side is top and should I line up the number with the dent?
One side is ribbed the other is not. My old bushings were so torn up I can’t tell which side should be up.
Ribbed side down?
Ribbed side down?
have both replacement bushings as well. no Difference one side to the other on those.
left is the moog. Right is duralast.
It has been discussed here before. see the "related topics" links at the bottom of this page
https://www.chevyhhr.net/forums/brak...bushing-37937/
https://www.chevyhhr.net/forums/prob...ntation-59722/
Any time , I’ve pressed in new bushings , I paid attention to those with the hinge like rubber, but the solid bushings , I measured both sides , they are the same, the bevel is the same, and I can’t get an answer of the manufacturer’s directions to install, so, they get pressed in .
