Coolant leak drivers side
Old 10-02-2023 | 02:23 PM
guppy's Avatar
I replaced oil pressure sensor yesterday, due to it leaking oil. I noticed coolant reservoir was only about 25% full, I added dex-cool so that is was about 3-4" from the top. I just pulled into work today and noticed the temp gauge was reading 214-216 as I was idling thru the parking lot. I pop the hood and I got coolant leaking onto the sub frame on the passenger side, below coolant reservoir. I could not find the source. I plan to top it off with some distilled water and jack it up when I get it home for a proper inspection. In the meantime where do you think it could be leaking from? I know you guys are usually dead right!
Old 10-02-2023 | 02:45 PM
fastsuv's Avatar
As I recall, the normal cold coolant level is pretty much at the 25% reservoir level.
If you overfilled it, it may have overflowed out of the tank once it got hot.
Was there any coolant leaking out before you added coolant?
Steve
Old 10-02-2023 | 03:02 PM
guppy's Avatar
Steve
I did not notice coolant leaking to begin with. After filling it up with coolant and taking it for a test drive yesterday, checking oil leak .. I noticed coolant. Then I realized that I did not snap coolant reservoir closed, so chalked it up as spillage. I snapped it closed and clean coolant off engine bay. But even if it were dripping from reservoir, this does not explain the 216 temp today.
Old 10-02-2023 | 03:09 PM
fastsuv's Avatar
What was the outside temperature when this happened?
The electric fan does not turn on until coolant reaches 219 degrees.
Steve
Old 10-02-2023 | 03:18 PM
guppy's Avatar
Steve
Arlington TX 90 degrees outside
Old 10-02-2023 | 04:00 PM
Look under the rad to cylinder head hose , the one with the radiator cap, that plastic piece has been known to crank and leak , I replaced mine with this style
https://www.fillernecksupply.com/1-1...e-cap-adapter/
Old 10-02-2023 | 04:20 PM
guppy's Avatar
Hey! I like that! I might just get one of those anyways. Thanks
Old 10-02-2023 | 04:35 PM
I agree with fastsuv, you overfilled the recovery tank.
https://www.chevyhhr.net/forums/main...ank-pic-55772/
Old 10-07-2023 | 11:48 AM
The purpose of the recovery tank is to collect the overflow of coolant caused by heat expansion, then returning it after the cool down. If you overfill the tank where do you suppose the extra coolant is going to go?
The cold fill mark is on the bottle way down by the indent.
Old 10-07-2023 | 10:47 PM
guppy's Avatar
you you are exactly correct. That is what I did and the coolant leak was nothing other than some over flow. Thanks everyone.
Quick Reply: Coolant leak drivers side
