coolant leak, steady stream
Old 12-30-2019 | 10:41 AM
It’s difficult when you change the water pump with the front cover on . Hard to line up the bolt holes with the sprocket tool in place
Old 12-30-2019 | 12:40 PM
That's what the tool is for! It has holes in the correct spots for the bolts.
Old 12-30-2019 | 01:40 PM
I’ve never used one , I always change the balance shaft chain and timing chain at water pump change time.
Old 12-30-2019 | 02:03 PM
Cat Man HHR's Avatar
Old 12-30-2019 | 02:39 PM
But how do you line up the new water pump bolt holes? From what I understand, you turn the impeller till they line up. Correct?
Old 12-30-2019 | 09:19 PM
UnknownError's Avatar
I found this video about the whine. Guy says that the timing tensioner has to be reset. I will probably replace the timing chains and stuffs no since in opening up the cover if I'm not. Where should I buy the timing kit? I saw the post with the video explaining everything but saw no links as to what kit to get.
Old 12-31-2019 | 08:35 AM
RockAuto, search 9-4201SX it doesn’t include crank or cam sprockets, or 9-4201SA that includes the crankshaft sprocket for the timing chain. And 9-4202S for the balance shaft chain kit with sprockets or 9-4202SX without sprockets .
Summit racing also carries them
the camshaft sprockets in the 9-4201S kit are not compatible with VVT in the 2.4 or 2.0 Ecotec or the 2009 thru 2011 2.2 with VVT
Old 12-31-2019 | 10:23 AM
This person explains chain whine and also how to use the tool.
Go to 10:21 for pump removal.
Listen earlier and he talks about the whine.
hhrmomma
12-18-2016 09:31 AM
bcp1975
03-23-2015 05:23 PM
tucsondivots
Maintenance and Upkeep
02-12-2014 09:43 PM
bcorg
09-16-2013 07:15 AM
donbrew
11-25-2012 09:37 AM
Quick Reply: coolant leak, steady stream
