Coolant Temperatures
Old 09-29-2017, 12:57 PM
racing123's Avatar
Issue I'm Having lately, Temps while driving 88C. (190F.)Stopped at a light temps reach 99C.(210F) (No AC on) Outside Temp 20C.(70F) any ideas. Ron.
racing123 is offline
Old 09-29-2017, 01:03 PM
Sounds normal to me; is this new behavior?
The fan doesn't turn on until about 219F. 190F is about normal for cruising.
donbrew is offline
Old 09-29-2017, 01:05 PM
Engine, trans, miles(Kms). Is this new behavior, if not, what preceded it?
Sounds just a tic high. When was the DexCool last changed?Even in an open system, 210* is not boiling; with the pressure, it's nowhere near boiling.
RJ_RS_SS_350 is online now
Year?
Engine?
Last coolant change?
What coolant was used?
Last thermostat change?
What stat was installed?
Was all the air burped out of the system?
All seem odd questions, however the HHR would be at least 6 years old , and so is past due for the coolant change.
These trucklets are designed for Dexcool 50/50 mixed with distilled water and the AC Delco thermostat.
Oldblue is offline
Old 09-29-2017, 01:09 PM
racing123's Avatar
yes just started yesterday, previous with outside temps at 85F, Air on, Temps would not reach 190F at idle. ?? tnx.
Old 09-29-2017, 01:15 PM
racing123's Avatar
2009 Panel, 12300 miles, coolant is original i assume,
Old 09-29-2017, 01:42 PM
OK, so if original, your coolant is right around 8 years old. DexCool has a maximum service life of 5 years. It's doing an adequate job at cooling/freeze protection, but the rust inhibitors are used up, and your engine may be starting to corrode on the inside, which also damages the coolant.
Time for a flush and a new ACDelco 131-158 thermostat. GM P/N 12622410
If you cheap out on the thermostat, you will probably have issues.
Old 09-29-2017, 01:47 PM
racing123's Avatar
Thank You RJ R.
Old 09-29-2017, 02:39 PM
(attn. One of the Mods should move this thread to the appropriate section )
firemangeorge is offline
Old 09-29-2017, 03:01 PM
Hold on , nothing up my sleeves!! Presto it’s moved!
Oldblue is offline
Quick Reply: Coolant Temperatures
