Coolant use
Coolant use
I have a 2008 lt2 with 30,000 miles that seems to use coolant.
I took it to the dealer for an oil change and mentioned a gurgling noise when I accelerate. they added coolant and told me that the newer coolants evaporate(?). 2,000 miles after they filled it its doing the same thing.
Can coolant really evaporate?
That is not sealed.. But yes the system is..
I had this same problem at about the same mileage. FWIW the dealer told me the two halves of the block were improperly fused together and the seam had failed, allowing coolant to leak out and bubbles to enter the system.
I'm happy to hear they're doing right by you and replacing the motor.
