Coolant use
Old 07-05-2010, 12:57 PM
06gray2ltHHR's Avatar
Originally Posted by plumb34
Since April they replaced the head gaskets. The same problem is still there so now they are replacing the engine.
shoulda asked them if they'd bump you up to the turbo engine
06gray2ltHHR is offline
Old 07-05-2010, 01:24 PM
JoeR's Avatar
Most of the posts in this "performance" thread should be relocated into either "problem" areas or (like "short ram intakes, and other BS!) into "appearance" threads.
Jeez this forum section has largely become real BS unless it relates to the problem aress.
JoeR is offline
Old 07-05-2010, 01:39 PM
ChevyMgr's Avatar
Moved.
ChevyMgr is offline
Old 07-06-2010, 12:53 AM
prod's Avatar
I also had the gurgling noise (seemed to come from right dash, probably where the heater core is). The service advisor told me that the high-mileage factory coolant can gel up and get caught in restrictive points of the system. They did a coolant flush and it does seem to be better now.
prod is offline
CoachJade
02-23-2014 09:21 AM
lil tank
12-30-2013 08:57 PM
Cheko0602
11-30-2013 10:49 AM
donbrew
11-25-2012 09:37 AM
andyb
12-20-2009 08:39 PM
Quick Reply: Coolant use
