Coolent leak
Old 07-10-2007 | 10:47 AM
jwb's Avatar
jwb
Red face Coolent leak
My hhr with the 2.2l coolent level in the anti freeze overflow tank is dropping by about an inch every 5,000 miles. Has anybody else have this problem?
Old 07-10-2007 | 03:11 PM
I'll have to actually remember to look, although mine is a 2.4l. Mine could've dropped by 4 inches.
Old 07-10-2007 | 04:23 PM
Snoopy's Avatar
Yes, it's hot here. Seems to be normal.
Old 07-10-2007 | 05:28 PM
Size:  5.6 KB to the site!!! I've never looked at my level
Old 07-10-2007 | 06:47 PM
crazybob's Avatar
An inch every 5000 miles seems excessive. I would suspect a leaking head gasket. Of course, it's not super hot here, either.
Make sure you're comparing the cold level to cold or hot to hot. The level is lower when the coolant has cooled down. When the engine is running, the coolant does expand some.
Old 07-10-2007 | 09:41 PM
Alzonie's Avatar
I don't think I've ever checked the level on the coolant overflow bottle since we've had our HHR. Probably should get back to checking stuff like that Monthly at least. jwb, There should be marks on your overflow bottle that say "Min" and "Max". Level shouldn't go much over Max when your engines hot, or much below Min when it's cold. If the level keeps dropping below the Min mark at the rate you're saying, something must be leaking somewhere for sure.
1970judge
08-14-2015 05:47 PM
hurst2001
08-04-2013 04:45 PM
gag
04-24-2013 11:10 AM
camaro98z28
08-30-2010 09:11 PM
blomb
07-03-2008 11:30 AM
Quick Reply: Coolent leak
