Could this cause ?
Old 05-23-2022 | 07:04 PM
Radco's Avatar
Could this cause ?
My son was having issue with stalling, Sputtering,n power
He found the air intake hose after the MAF was off between the MAF and AF box !! Would or could that cause those issue's with the mixture ?
I am 1 hr away so my info is from a phone chat with him
Old 05-23-2022 | 07:58 PM
yes
Old 05-23-2022 | 08:24 PM
Radco's Avatar
Originally Posted by donbrew
yes
Thanks for the reply Don. I thought so but my auto mechanic skills are fair at best lol I was guessing that sucking air in after the MAF would mess it up , Good to have it confirmed
Old 05-23-2022 | 09:28 PM
Is there supposed to be a clamp on that hose ?
Old 05-23-2022 | 09:55 PM
Bonez's Avatar
The clamp is there, just tucked up under the airbox a bit, you can see it.... you circled the rib just bellow it
Old 05-24-2022 | 07:19 AM
A cracked AF box neck would allow more unfiltered air in.
Here’s a shot of the MAF location, just the other side of the elbow and that clamp
Here you can see the neck , now if it’s cracked before the MAF , it’s going to allow that unfiltered air in but before the MAF , can cause the MAF to read incorrectly.
Old 05-24-2022 | 07:28 AM
Radco's Avatar
George. Yes there is.
As far as I know he did !
He said he tightened it when put back together ! But a great question, And I will double check with him that he did put the clamp back to be sure !
Old 05-24-2022 | 07:34 AM
Radco's Avatar
Thumbs up
Great pics Steve , Thanks
In the past month or 2 learned more about fixing the HHR then ever lol. Can now add the intake hose issue to the list of problems solved lol
THANK YOU everyone for your help. Really helps a NON GEAR HEAD like me
Old 05-24-2022 | 09:34 AM
A leak BEFORE the MAF will only admit unfiltered air. A leak AFTER the MAF will cause unmetered air, causing a lean A/F.
As these cars age the rubber tends to crack where the breather enters the EL.
Old 05-24-2022 | 12:03 PM
Radco's Avatar
Thumbs up
Don again Thank You for explaining things to me. I sort of understood it before but I was guessing lol. Now I know the whats and whys :)
Thanks
Quick Reply: Could this cause ?
