Cover under Fender near Front Tires - Mounting Problems!
Old 02-20-2008, 06:49 PM
dvalin's Avatar
Hey!
Some days ago, I hit a Coyote with my HHR at around 70mph - I think my front license plate hit it and then, I ran over it with my left front tire. The coyote was dead
So, my car only shows minor damage. The left plastic cover of the foglights-openings is pushed into the body. Also, this big plastic cover thing under the fender and in the wheelhouse is a little bit loose because some of those plastic "rivet" are broken.
Where can I get some new of those? Shall I just go to my Chevy dealer?
Thanks! Dvalin
dvalin is offline
Old 02-20-2008, 06:52 PM
I dub thee "The Coyote Killer" Are you going to try and match The Deer Slayer's Record?
I would guess the parts dept. at the dealership should be able to get these for you.
HillsdaleHHR is offline
Old 02-20-2008, 07:18 PM
TomsHHR's Avatar
Location: Superior, WI - Over the Hill Warranty Club member
And I am at 4 now...
I can feel the pain....
TomsHHR is offline
Old 02-20-2008, 07:19 PM
an08HHR's Avatar
Those xmas tree connectors can also be obtained at some auto part stores. They come in different sizes. Pull out one of your old ones and take it with you. Dealer might have some in stock but definitely would if they have a on site body shop. Any body shop should have any you need and most likely would know which ones you need if some were missing.
so long Wile E. Coyote, HHR 1 Coyote 0
an08HHR is offline
Old 02-20-2008, 08:53 PM
Smoke Wagon's Avatar
an08HHR is right. Some auto part stores have what they call a HELP section. They sell everything from window crank handle locking clips, to inner fender double-lock push clips...
I am sure the dealer can get them, but often they sell them in packets of more than 1...which is ok...nothing wrong with having spares.
Smoke Wagon is offline
Old 02-20-2008, 10:22 PM
jeffs396's Avatar
Or maybe...the ROADRUNNER!
jeffs396 is offline
DwRed2LT
05-09-2015 01:05 AM
jimmycrook
03-13-2014 08:02 AM
HHR911
03-30-2012 11:11 PM
bigjacksauto
12-16-2011 05:16 PM
Quick Reply: Cover under Fender near Front Tires - Mounting Problems!
