Crank position sensor
Hello everyone. I was wondering if any one else is having the issue I am having. I am getting codes for the crank position sensor and I believe its not getting enough volts. I tested the wires and I'm getting 5 volts from 2 of the wires and I assume the 3rd is the signal wire. The only thing I can think of is one if the control modules are bad or their is a short.
2010
2.4l
2010
2.4l
IF all of the wires and connectors are good the sensor must be bad.
P0365 is NOT the crankshaft sensor it IS the exhaust camshaft sensor. Likewise a wire/connector/sensor problem.
Here are the testing procedures:
P0335
P0365
P0335
P0365
I do notice to inspect the timing chain and oil debris in the P0335 description, a loose chain will through off the cam and crankshaft position correlations
How many miles since last timing chain and tensioner?
