Crank position sensor
Old 08-13-2021 | 09:21 AM
Madmec's Avatar
I assume never. It has only 87 ish thousand miles. I do believe it has something to do with the crank sensor because when I look at rpm with my scan tool it says 0. So that tells me it not getting a signal correct?
Old 08-13-2021 | 09:33 AM
I would discard the suggestion to replace the ECM; much more likely a wire or the sensor.
Chrris F
2.2L Performance Tech
7
06-26-2019 03:08 AM
Greenstu1
11-28-2017 07:42 PM
mr chevelle
02-19-2013 06:02 PM
68 redrat
11-20-2012 09:35 PM
sndsgood
04-30-2011 07:18 PM
Quick Reply: Crank position sensor
