Cranks without key
Old 06-24-2019 | 11:35 AM
Not sure Don. If they somehow reversed the battery cables, then the main hot wire would now be a ground at the starter. Can't see how the OP's car would be turning over if there's no + connection at the starter motor with reversed cables.
Got to be a dead short between the + and - somewhere.
Old 06-24-2019 | 11:43 AM
He said the the engine tested +.
Old 06-24-2019 | 01:27 PM
Tallcolorado's Avatar
Ok I unhooked wire harness and all grounds to motor... still pulling voltage from motor to frame. And its surges .2v to 2v. I'm at a loss of what can be throwing voltage to it now.
Old 06-24-2019 | 01:47 PM
Are you going to do anything we asked about? How can you remove grounds to the motor; which motor?
Old 06-24-2019 | 02:57 PM
Ashley Spooner Blanton's Avatar
Maybe clear up what you say it's doing.
Is it turning over(starter engaging) and starting the engine ? Or, is it just turning over continuously (starter) and NOT starting the engine ?
Just turning over it will NOT start the engine it just keeps trying
Old 06-24-2019 | 03:03 PM
Ok, so the starter runs all the time. Sounds like a bad starter or a bad relay.
Old 06-24-2019 | 03:08 PM
Cat Man HHR's Avatar
This person Ashley doesn't know that they are hijacking this thread.
Old 06-24-2019 | 04:00 PM
OK. Who are you and why are you trolling someone else's thread ?
Old 06-24-2019 | 04:10 PM
Same ip address... Same person, or family member maybe.
Old 06-24-2019 | 04:34 PM
Ashley is my wife... both trying to keep up to get this thing fixed.
Quick Reply: Cranks without key
