cruise control
cruise control
I can't set my cruise. I can turn it on but i wont let me set it. Im thinking the 2 top 2 controls(i have 4 small and the big 1 in the sise) just have a blown fuse but i cant find it. ??? thanks
On your 2010 Ls. Could be a fuse.Not sure what # fuse it is. Or could be a burned out brake light bulb.Check those.
Anything else,take it to the dealer because I'm guessing you're still under warranty.
Read my answer in the other post where you asked about this. Also you lost me on this description . Are you talking about the buttons on the steering wheel? And what is a "sise" ?
Always state the year, model and engine when asking for help.
Certain CEL's (check engine light codes) will disable the cruise control. Do you have a check engine light on ? Also, some codes will not trigger the CEL but will be stored in the car's computer. You'll have to use a code reader to check.
AND. A burned out 3rd brake light bulb will render the cruise inoperable. Check your brake light bulbs.
dbldown
02-19-2014 08:08 AM
hhrumadbruh
10-26-2012 07:53 PM
