curb idle rpm
curb idle rpm
Just a curious question what does the HHR idle @ with warm engine in gear mine idles at about 850/900 I am thinkin this is high btw the Ac on /off makes no difference .I am lookin for the reson the mpg feel off , recent drop from 29/30 to 27/28 I just tried Seafoam I normally do not use such stuff , But I am tryin Thanks in advance
You are within spec with your idle speed according to the service manuals. The reason engaging the A/C makes no difference in idle speed is because the ECM automatically compensates for the load of the A/C compressor when you push the button, hence no rpm drop.
A drop of 2 mpg could be down to the higher Summer temperatures, possibly increased rolling resistance due to under inflated tires, reformulated gasoline sold during warm weather months, or a half dozen other things.
How many miles do you have on your HHR, when was the air filter last replaced, is it due for a plug change, or have your driving habits or route changed? Just some of the things you need to consider when chasing a mpg drop, I wouldn't be overly concerned by a mild drop in mileage as it doesn't take much to skew your overall average.
Thanks guys , the hhr has a bit over 130,000 miles i do hva e the oil change up to date , i run amsoil , the air filter could probably stand a change the humidity well this is the south , I am thinkin a stuck idle motor
tiggercross59
06-26-2014 04:18 PM
