CV Axle
Old 07-15-2013, 08:06 PM
Originally Posted by geoketch22
I got 103,000 on my 2006 HHR, been in the shop for campaign letters and recalls for safety items. 1st was the A/C unit on the firewall, when it rained it filled the passengers floor board. Then the the front end started to give problems took it to chevrolet dealer where i bought it, couldn't find the problem. They did change the brake disks on the front and turned the rotors. which i replaced with high quality alloy rotors ended brake problems. Steering shaft started to make noise and took it back to dealer prior to extended warranty running out at 70,000, they couldn't find it again but they did change the water pump. The key pads to unlock the car and remote start died, the dealer exchanged them, ( no charge) but still couldn't find the noise in the steering shaft or the front end. At 90,000 I changed the entire strut system (that was a bigger to change) on the car, helped somewhat, now the CV joints are bad. Front was designed wrong, much too light for the vehicle.
thanx for your time
Yeah, ALL GM cars are good to moan and groan about, the dam things wear out and force you to post in un related threads. Probably not the CV, but hub/bearings were always the problem.
Dam, STILL a bad day! sorry.
donbrew is offline
webpirate
04-24-2015 02:35 AM
gio89kid
01-03-2015 10:49 AM
06burntorange
Maintenance and Upkeep
26
11-10-2014 08:05 AM
maddawg
08-12-2014 10:21 PM
OldSchool57
Drivetrain (Excluding Engine)
10
06-17-2013 07:02 AM
Quick Reply: CV Axle
